timing
capesr20
I had a coolant leak and my car over heated and now that I fixed it. it seams to be surging and I cant get the timing right I set it to top dead center and the car runs like crap and I have to set the timing back to get it to run smooth. does anyone know what the timing shound be for an sr20det black top.
thanks
SpeedRacer1
Car: 1990 240SX, G35
15 degrees behind tdc. Thats why it runs better when you turn it back.
If its at TDC, the combustion is horrible.
f150intally
when looking at the motor from the front with a timing light hooked up, what mark is 15 degrees? I think it is the second from the left but is this standing in front of the car looking down? Mine is like 5 marks from the left if I'm standing in front of the car looking down.
The only reason I ask is because I got some detonation last night at 5000 rpm.
- Jay
SpeedRacer1
pgt892
Car: 1997 240SX
http://www.store.yahoo.com/pha....htmlPhase 2 has a great page that explains how to set the timing using the CAS.
f150intally
Yeah, I knew how to set the timing at 15 degrees but I was just wondering where it should be when looking at it with a light.
That image explains it all, thanks!
martin
SpeedRacer1 wrote:15 degrees behind tdc. Thats why it runs better when you turn it back.
B = Before TDC
gtune4
Car: toonah
make sure you get all the air bubbles out of your coolant. the stock temp sensor plays on the idle and may affect your ability to set timiming.
loudbay
Car: duh
i just finished my swap, and i am only getting spark to the front cylinder.... i've checked everything it seems like, could it be my timing? thanks
gtune4
Car: toonah
i would check all of your wiring first. then check the ignitor chip?
loudbay
Car: duh
thanks, i'm pretty sure my wiring is good. have you guys found any problems with the instructions that are readily available on the net or in mags? they all seem to be the same to me.... and i think mine is right......
