dogred »
https://forums.nicoclub.com/dogred-u134060.html
Thu Sep 24, 2009 10:11 am
Go out to your truck, mark the posistion of the distributor where it sits now, so you can realign if what I tell you does not help. Now remove the upper half of the distributor. Loosen up the bolts on the block and reinstall the distributor top half, it should now be 180 degress from where it was before. Tighten it all back up and test.
