timing
donmada
Car: 91 240sx with a s13 black top sr20det
when doing the timing all the little notches on the front of the pully on the crankshaft do you put it to the 2nd notch on the right or the 2nd on the left and with the cas is it the notch that is lower or the notch ath is higher for the 2 side by side
