Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Mar 11, 2003 12:30 am
The easiest way is with the special adapter [$200] which plugs into the driverside ignition harness.The CAS has a wide range in the slot [-25 ---+15] and setting 1.0 degrees resolution is tricky. The normal position shows about 1/5-1/4 of the slot exposed to the right.
Follow the instructions in your shop manual closely as to locking out the IAC, setting rpm and making sure the coolant temp has stablized at 176F [minimum].
15 Deg BTDC [as measured with timing light at crankshaft pulley] is ideal as 17 will cause over activity in knock sensors and limit full advance in summer heat further reducing power.............some run 13 degrees which will only droppower at 4,000 rpm by 1-2%.
The Consult always reads 15 degrees at idle [in park]because it assumes you have set the CAS properly [in drive it changes to 20 degrees].
{{Checking the maximum advance is productive it should be 26-28 degrees under WOT as you exceed 6,000 rpm [lower around 22-24 at 4,000]...............at 2,000 rpm cruise light load steady speed it might get to 40 degrees ......the above requires a Consult}}
