silvia_ca18det »
https://forums.nicoclub.com/silvia-ca18det-u31594.html
Thu Jan 19, 2006 2:00 pm
ok so i did the timing chain once allready the motor wasnt sitting on the motor mounts so i adjusted it and it kinda fell into place! not hard but yeah, now i went to start the car and it get way to much fuel, its got z32 and 550s and a tune for it! i took off the valve cover and the timing marsk are off 4 teeth on the cams! my question is did the gears all slip? i set everything right when i stuck the timing chaine in the first time! and i dont think that the motor being bounced around that hard would even mess with the timing chain?
thanks
