TIMING?!
sunnys14
Car: S14
is it .5 degrees for every 1lbs of boost or .5degrees of retard for every 1lbs of boost OVER 8psi? im hearing alot of different answer from different people. can anyone confirm this please?
Craving4Boost
Car: 91 240sx fastback
how do you retard timing only after 8psi? i know my msd btm just retards after every lbs of boost.......is there another unit that can contorl it after 8psi?
MarkEmark
Car: fully-built '95 240sx KA-T
sunnys14 wrote:is it .5 degrees for every 1lbs of boost or .5degrees of retard for every 1lbs of boost OVER 8psi? im hearing alot of different answer from different people. can anyone confirm this please?
I would say after 7-8 psi, assuming you're running an efficient intercooler and 93 octane gas.
Because at that logic, if you were running 16 psi of boost, you'd have 8 degrees retard, or a base timing of 12 deg. btdc, which is absurd.
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
i'd go with what orion says, for a stock compression engine running over 10 psi, i say retarding .75 degree per psi is fine. my jwt is running 17-18 degrees of total timing at redline when i'm running 14 psi. which is about right. and when i try to advance it alittle more, i pick up knock readings on my safcII.
DammitBobby
Car: S13 91 KA24DET
Hey have you dynoed since you installed your JWT ECU ? Curios because I bought a used one and it is on its way 72lbs program.
sunnys14
Car: S14
i meant, should i just leave it at stock timing which is 20btdc when im running 8psi? or should i retard it 4 degrees base timing?
S14tat
Car: 2007 FX35
1994 Acura NSX
you should retard it, i mean its better to be safe then sorry right?
and rseabrook, i didn't get a chance to dyno yet, some unexpected expenses started to pile up such as a minor collish with a car to my door ( no fault cuase my door hit the side of his car ) and i needed new tires, and i needed to fix my a/c. i'm gonna wait till like the end of summer when it cools down get dynoed.
sunnys14
Car: S14
so running 8psi, how much retard should i go from base timing?
Craving4Boost
go with cheap water injection and dont retard timing at all....sounds nice doesnt it
huguetpj
Car: 93 KAT Coupe
sunnys14 wrote:so running 8psi, how much retard should i go from base timing?
Set it at 15-16BTDC.... for those hot days.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Timing? You ask 10 people you will get 10 different answers.
Imo...Stock timing should be kept only if running water injection with high octane fuel (91-93)
.5 for every lb of boost is the most common and seems to work well for everyone.
