Timing
poly
Car: J30t
95 J30T 160km
Two weeks ago I had my timing changed at a dealer and the car is not running smooth as I first brought it in.
I am hearing a knocking noise nowLoss powershakes alittle.
Is this timimg off?
s13sr20chris
thats bad. its hard to say if the timing is off but you should def go back and complain.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Please clarify, knocking as in detonation or in metal on metal concussions? How does it idle? Any reluctance to start? Higher rpm performance?
truckboy
your problem has nothing to do with a timing chain , the time has come to go to a specialist engine tune and diagnostic /repair shop
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
It could have been set improperly, but why did you have the dealer doing the timing in the first place? Was there something else going on?
