pampadori »
https://forums.nicoclub.com/pampadori-u628.html
Mon Feb 10, 2003 4:25 am
warm engineturn off key and unplug tps sensor.restart and let idle for 2 minutes. adjust idle so that its around 750rpmloosen the two 12mm bolts for the cas.hook timing light to black loop wire on rear on valvecover. adjust timing so that mark is on 2nd from the right notch on the crank pulley. this is 15 degrees. feeling froggy? set it to 17 degress, or between the first and second notch from the right. turn off engine. plug the tps back in. restart and make sure idle is around 800rpm.shaun
