Timing specs is 20 degrees. This is the far right mark at your pulley. Then distributor rotor needs to be pointing towards pistong number one. Right?
Then disconnect tps and get it to 650 rpm shut and turn on with tps connector and it should be @ 700 and if not this is where you adjust your dis, or your idle screw right>? Just want to make sure. its been a while.
