Best thing to do, is get or build a timing chain tool. Basically its a tool that goes in the hole when you take your cam gear off to take off the head. The too holds the tensioner in and holds up the chain up it doesn't fall. This will allow you to just take off the head, with out having to take the front timing cover off
Make sure you make a mark on link and sprocket, and set the engine at TDC.
Here is a picture of a tool I made out of pcv pipe and electrical tape hehe. Notice the pcv pipe and the chain on it, Bottom had some electrical tape wrapped on it to fit snuggly into the hole, to hold the tensioner in. Il take a better pic tomorrow if needed.
