Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Jul 31, 2002 11:17 am
Understand that Redline wetter water helps remove heat from the combustion chamber making the coolant temperature HOTTER as it leaves the head where it passes the ecu coolant temp sensor. So the ecu will see 1,2,3 F hotter temperature, but the radiater is more efficient as the temperature rises so the water returning to the engine will be cooler by 1,2,3,4,5F.Water has almost twice the heat absorbsion capacity as AF so the less percentage of AF you run the more heat it takes to heat the coolant up to a given temperature.Pouring wetter water into a 50/50 coolant doesn't do much vs using it with a 20-25% AF.If your radiator is marginal or your thermostat more than 2-3 years old the coolant system will not stablize at the correct temperature.
Any coolant temp above 190-194F as read by Consult will start a chain of power reduction. The 195-204F range is not too critical as only a 2 degree reduction occurs in timing but this coupled with the 1% for every 11F ambient gets noticable at aroud 90F showing on the outside temp AC indicator as it creates a 5% reduction. But the engine itself accelerates poorly when the advance is below optimum.
If the knock sensors are activated in addition to the above the power drop is signficant with a 10-15 degree advance reduction.
Really the only way to tell for sure is to do a series of WOT runsand record the data, focusing on the ignition advance under load and rpm [ should be 28 degrees at 6,000-6,900 rpm]......have tested some Q which reduced to 15-17 degrees.Good idea to plot the coolant temp vs minutes of idle in gear and learn the rise per minute. Most are 2F per minute so 15 minutes in gear without moving will take you up 30F or more.Which is ok for mine since I might come off an Interstate at 175F so 205F but those with marginal systems in the first place might start at 195F and get to 225F or worse!
Have seen some Q which run around a 220F normally [with a 5 degree timing reduction] then spike to 250-260F [boiling coolant]in traffic and quickly overheat in ONLY 5-7 minutes.
If the radiator has over 70-80k look there first.Getting as new performance [resistance to overheat] always means you end up replacing it.The foam surrounds rot letting engine air suck into and mix with the relatively cooler air in front of the radiator, any restriction in the condenser makes it worse.
There is a new design plastic fan similar to the 94 and up designed to pull a little more at slow speeds.
!!!!!Understand what I relate on this forum is many times VERY technical and not well understood by even T3 technicans and surely not by many/most dealer technicans.They are too use to dealing with customers who don't want to spend to even think of fine tuning.
Intrepreting the 170F thermostat opening vs 194F max lift means an average of 182F and the constant use of the 176F minimum test temp[and the 176F reference for the coolant temp sensor resistance] is an engineers way of implying that 176F-182F is what he designed for!!!!!
My standards are that of the engineers that designed the Q.
I have tested about 9 Q in depth [multiple temp probes, consult, stop watch, 2 hour testing minute by minute logging] and 90% of those with over 7 years needed a new factory radiator and all it's accutremants.
Not many would pay $300 for me to do a diagnostic and provide temp charts, graphs, et all -- when that could just be applied towards replacing the radiator and thermostat.
