timing rattle question
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
I just went to fix my timing chain rattle, and when i set the #1 cylinder at TDC i don't know if it was on the compression stroke or not, does this matter? or is it ok as long as its on the compression stroke?
Structure240sx
did you line it up using the marks on the crankshaft pulley? if so then it is right
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
yep, i actually got it to start and its all good, but i was worried for a few moments there
