psmith »
https://forums.nicoclub.com/psmith-u91039.html
Thu Apr 03, 2008 3:36 am
I know this a frequent question and post subject so I thought I would share my limited experience... I pulled out the guides about a month ago on my motor. The process went very smooth, but the noise was still there.(Although quieter). Now I started searching more and more to try and find the answers. First off, I worked the upper tensioner free as is mentioned in the write-up on this topic. I could barely move the lower tensioner, but that is not something that can be easliy removed, so I decided to close it up and try it out. Noise was still there. Low Oil Pressure??? Ran a small amount of Seafoam through the motor and went from 5w-30 to 10w-30. Still no change.I purchased a new set of tensioners and took things apart last night.This time I could move the lower tensioner a little bit. So I went to work on freeing that up some more with penetrating oil. Replaced the upper tensioner and closed things up. Result- this morning HUGE difference.Everything is quiet and I can finally hear the motor, not that annoying rattle. Sorry for the long post I just wanted to say that I think too much stress is placed on removing the guides and not enough on making sure the tensioners are working properly...
