NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Wed Oct 12, 2005 10:04 pm
Depends on a lot of things.
Anything that can affect the mixture burn quality such as:-intercooler efficiency-engine temp-inlet air temp-turbo efficiency at specified boost-a/f ratio-exhaust backpressure-fuel octaneprobably more i cant think of at 1am..
In other words if you have a full system you can run a little more timing. If you have just a half-baked homebrew turbo kit with a small turbo and a SR SMIC you wont be able to get as much without detonating. It all depends, unfortunately.
If you have the best of everything in that list I would say you can run 8psi without retarding timing. However, if, for example you have everything except high octane gas (you can only run 91 octane), you will be wanting to retard timing at least a couple of degrees.
check out kennebell.net in the tech section there is a great article in there that relates timing/a/f ratio/octane/temps to the amount of boost you can run.
