3:20am and I can't sleep because I would like to get to the bottom of this. I can promise you that I have been researching this timing topic for at least 3 - 4 hours.
This is what I did;
zer...ssues
Question #1 About Timing;After installing the dis back on TDC do you now move the crank and align it to 20 degrees?
Note: After hours of trying to start my car I aligned the shaft markers to my shaft indent and installed it at TDC, and started the car, the idle seems fine but the response sluggish.
Question #2 Timing Light;May some one explain this to me as if I had no knowledge of what I am doing?
(I've read the tutorials but I still don't get it, please be as detailed as possible)
I really appreciate it.
I read this tutorial and many others;
zerothread/358264
