RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Sun Oct 31, 2004 7:03 pm
1993 fastback. DOHC
I recently did a head swap, and a new head gasket. I've got the timing all lined up: the distributor is at/near 1 where is should be, the crank timing mark is at the second to the last mark (TDC) and the cams are pointing away from the spark plug on cylinder #1. But for some reason I still cant get the motor to start. It seems like if I remove the fuel pump fuse, it'll want to run. But with the fuel pump on, it wont catch at all..... Timing light shows the correct timing..... Dont know what else to do...Help please
-R
