N1ceDrgn »
https://forums.nicoclub.com/n1cedrgn-u1722.html
Thu May 06, 2004 2:54 am
As for management, I using the SAFC 2 and the AVCR. Then added to that, I got a rom tune before I left Japan. So, as far as that's concerned, I've got that covered. My only regret is not getting a backup computer that I could play with. No one here in the states (that I've been able to find) can tune a CA.Back to the main topic at hand though, I went and set things at 15d btdc. Before I reset things, the last tuner I worked with had me set at 20d btdc! Which was a shocker! After it's all said and done though, I'm still not boosting right for some reason and my oil pressure is high now as well. Stock/ normal is some where between 2-3 bar, I'm now sitting at around 4. My idle is the same, it's set for 900-1K. So, once again I'm back to square one. I double-checked myself with the FSM's I have on hand and what I did is what they say to do. So, I'm stumped. If anyone has any ideas, I'm game.**In case the tone went south earlier in all this, I wasn't out to piss in anyone's cereal nor was I looking for it. I usually don't bother with the forums because of that. I'm hoping this will explain why I only have a count of something like 13 or 14.
