timing question
xKnownShadowX
Car: 94 Q45a
I'm curious how man rotations of the cam does it take to line the timing chain with the punch mark on the cam again?
I got the crank a tdc and the cam at tdc but when i rotate it doesn't line up again so I wanna know how many turns cause after a few it lined up again.thanks
edwards30
Car: 1995 240sx SE
i think four. Should be intake stroke, compression stroke, power stroke, then exhaust stroke. Someone correct me if i'm wrong
xKnownShadowX
Car: 94 Q45a
I think you maybe correct I counted it and it took four complete turns.I put the crank at TDC which is piston #1 all the way up correct?On the cam the punch mark isn't at 5 o'clock but the pully timing mark lines up when its at TDC so should I just do it like that?
edwards30
Car: 1995 240sx SE
TDC is the Piston #1 all the way up so thats correct. I'm assuming this is a SOHC motor right?
xKnownShadowX
Car: 94 Q45a
Yes it's SOHC and I guess the sprocket is upside down or something.I didn't put it on but I just put it at TDC and lined up the pulley so it should be fine right?
edwards30
Car: 1995 240sx SE
where should your punch mark be according to your repair book or what not? I'm not too well versed with SOHC engines but it should be easier than a DOHC
xKnownShadowX
Car: 94 Q45a
says 5 o'clock but tdc.i hand crank it and it spins freely.
edwards30
Car: 1995 240sx SE
i'm not forsure, i guess i'm only good for answering your first question. Good luck! Sorry i can't be more help.
