Nismo_Freak wrote:Cam Bolts - 125 ft. lbs. Cap Bolts - 8 ft. lbs.
Be sure to loosen and tighten the cam caps in the correct sequence.
Yes it's a bolt on thing, but you'll need to check the valve lash (basically make sure your shims are correct) since the KA has mechanical lash adjustment. Incorrect lash sounds like a worn out lifter... loud valvetrain operation and it gets faster and louder with RPMs.
The KA is interferance so VERIFY your cam timing.
Set the engine at TDC on cylinder one (basically line up the cam timing marks and the timing chain marks). It allows you to visually see if the timing has moved.
You'll need assembly lube for the cam install... make sure your liberal with it on all the frictional surfaces. Seized cam = broken stuff very quickly.
Thanks for the good info. I have the FSM, so i know the tq for the caps and gears already. If i am correct, the only thing that i really need is a feeler gauge to check the valve lash once the thing has warmed up.
Do you think that using a set of 240/248's from a '91, that I will have to replace any shims?
I am trying to do this on the cheap. And if I don't feel comfortable with it, I am going to have to shell out the bucks and get it done by a local shop. (
http://www.balancedperformance.com). The only thing that I don't like is that they told me that it is going to be 250 labor because they have to pull the timing covers and retime once they are done. This was contrary to all that I have read in the past. Maybe if they wanted to throw in some dyno time to tune it, but not just for a cam swap.
So I started researching and asking questions. The best document that I came up with was from a google search that ended up at JWT. They have a cam swap document for the ka24de with photos and everything. Best that I have seen so far.
I am extremely mechanically inclined. I have worked on electrical, maintenance, suspension, interior, custom fab work for stereo, custom alternator/pulley setups. (Installed professionally for about 6 years with a good Atlanta shop.) But I have never done any internal work on a large motor. (Everyone has pulled apart a lawnmower or two.)
I am figuring that this is probably the easiest place to start. Please correct me if I am wrong.
