Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Tue Aug 04, 2009 4:25 pm
What should my timing be doing when the engine is under load? I finally figured out my AFR issues (multiple pre-sensor exhaust leaks) and now I'm trying to figure out my breaking up/bogging down issue. I don't think it's fuel because I'm backfiring with flames, meaning there is fuel present during the breaking up. I hooked up my consult cable so I can see what it's doing, and I'm really not sure what I'm looking at. I know that my injector duty cycles aren't maxing out, and neither is my maf, so I checked to see what my timing was doing.
At idle it's at 20 degrees btdc, which is what it's supposed to be. Under load however, I saw it go to 40 degrees btdc. This wasn't even in boost, just under load. Could the ECU be pulling timing so much that it is making the car bog/break down under heavy load? I mean it could, but I have no idea what the timing is supposed to be under load.
I also dumped my tune to my desktop so I can upload it if anyone wants to look at it. I highly doubt it's the tune but at this point I'm open to any suggestions.
I checked for boost leaks and I have a minor boost leak at my bov. Like barely leaking at 20 lbs of pressure, and I'm only running 7 lbs. The backfiring makes it seem like I might have a boost leak, but the test didn't show any huge leaks that could make the bogging this drastic. Any help is appreciated.
Thanks
