s13rb25det »
https://forums.nicoclub.com/s13rb25det-u27134.html
Mon Mar 05, 2007 6:26 pm
hello, I am currently rebuilding my ka24de. I have currently gotten to the timing of the engine and am stuck because I can not find any timing marks on the lower timing chain. my question is could I just set my #1 cyl, to TDC and set my lower timing even if the markings on the crankshaft sprocket and the idler sprocket are off? I know I have to get my cams aligned perfect and im sure I can do that. its just the lower timing that I am concerned about. it shouldent be a problem if my #1 cyl,at TDC right? I have no markings on my upper timing chain also,so I was hoping to just set the cams the way on the JWT website. I could just use like paint or something to mark the chain. and then set my dist, to #1 cyl, is there any problems with this set up? has anyone ever had this problem before? I dont see why this would be a problem if I am at #1 tdc and my cams and dist, are aligned. what is even the point of having the marks on the timing chain anyway? please let me know so I can finish my engine. thanks
