I replaced the head and timing chain in my sohc ka24e after i bent the valves in my old one. When putting it together i had it at tdc on comp stroke and installed everything but then a friend turned it so that the top sprocket went around maybe 3 full times.
Does this matter? The timing and all would still be set right?
--Tim--
