he's right mine had yellow in the punch marks too. but on your cas you should only have two marks that get aligned when you insert your cas into the head. or is it three, one slot mark and two round hole marks, hence the illistation. you should really try to post some pics so we could better help you with your problemtenkawa_akito wrote:The marks on the CAS are more like punch marks. I think the ones on mine may have had yellow filled in, but it's been years since I installed a CAS.
