I put the rotor in the same position as the old one, I would also like to know how to check that the rotor is in the correct position
s13sr20chris wrote:the rotor only goes on one way. it should bolt in there too.
It appears to be hex shaped and there is no idiot slot to keep you from putting it on wrong.
did you unplug the tps? you will need to do that to set the timing. how does your car run?
TPSI still have to purchase the manual for this car and am having a difficult time finding one
I tuned it by ear (I guess with the TPS plugged in) and got it where it is no longer pushing so many hydrocarbons but Co has gone up. (but she got power back :pface
if it runs bad you may have a prob with your valve timing or dist timing. what emissions did it fail for?
