Timing problems
ZwhiteshadowZ
I just bought a 240sx that has been sittin for acouple years... when i first got the intake manifold gasket was bad so i replaced and it ran fine.. i took it for a test run and got it up to about 7g and a knock started and it started running on 2 cylinders with a horrible shake when it idles... so i took off vavle cover and adjusted the timing chain but cylinders 2,4 still have low compression any ideas?
NISTECH
you probably bent valves if you had to adjust the timing chain.
240A4
Car: anything that related to car
check the valve spring. it might be the couse of bent valve.
ZwhiteshadowZ
Ive looked at all the valves... none are bent...
navysnail
maby head gasket
