Timing Problem with my KA24DE
Tico240sx
Car: Nissan 240 SX S13
I have a KA24DE.... I had the entire top block replaced... and guy doing the work took off the head....had all the parts replaced and put it back on with the chains where they were before... the engine wont crank over...it seems like it wants to start but it wont... I NEED HELP....
Terrorinc17
Car: S14
Are you absolutly sure the cam timing is correct?
Do you have fuel and spark? Is distributor set correctly?
lanerjo
Car: 1990 240SX w/ RB20DET
1993 Pathfinder 4x4
1995 240sx Ka-T
first things first...Never let anyone else work on your car
Take off the timing cover and rotate the motor by hand... make sure the timing marks on both the intake and exhaust cams are in the proper location when the Crank mark is lined up with it's timing mark.
Second with the motor at TDC on the compression stroke make sure that the distributor is pointing at the number 1 Ignition wire
Check to make sure the wires are in the proper firing order
these should help
