Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Tue Dec 31, 2002 2:03 pm
OK... I got the engine running today and set the timing to 15 deg. BTDC. Works fine, except now I hear this high-pitched tapping sound, doesn't go away, and the volume will increase with higher revs. My oil light is also about halfway on, even though I checked the level with the engine warm and it looked ok. My seat belt light is also on for some reason also. Any advice on the noise?
Oh yeah, in response to the question about the crank and the cam, the person that owned the car before me must have done this job, because the guides were fairly new. But the alignment for the chain was off... when the dot on the cam sprocket was on the right, the dot on the crank sprocket was on the upper left... so I just counted the links on the right side of the chain and installed the new chain with the same amount of links.... is there any harm in doing that?
Dan
