180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon May 17, 2004 3:52 am
each of those dots are supposed to read 5 degrees and the count starts from -5 degrees. Surprisingly I fixed this problem on my buddy's DOHC yesterday. I'm also assuming you've got a timing light, 10mm socket, and a philips head screwdriver. I'm also assuming that you have tried rotating the base of the distributor and hit one of those ends that limit the movement of the distributor. If you haven't done that, then try it and fix your timing accordingly. If not then here's what I did.
Get down to the rotor of your distributor. rotate your crank pulley to the second mark to set you to 0 degrees, when you hit tdc, you'll also see the distributor point to the front of the car. If it isn't then try again and get as close as possible. what we had to do was pull the distributor and adjust it till we had a bit more space for adjusting the distributor than before. just moved it over like a tooth or two, nothing major since that one or two teeth allows for alot of adjustment.
