b1ks14 »
https://forums.nicoclub.com/b1ks14-u33034.html
Wed Sep 28, 2005 10:52 pm
A timing light was used. Timing was slightly retarded but the cas was advanced all the way. The rb25 was recently installed. I have pretty much everything stock with the exception of a greddy intake manifold, metal head gasket, boost controller, fuel controller, fmt intercooler, and fuel pump. I had to increase the fuel by 20 units on my Apexi SAFC to run right. If i put the settings at stock than it boggs big time. I'm only boostin 10 lbs. on a stock turbo. If I try to adjust the cas more towards the center than it won't rev past 5000 rpms. Aside from the bogging the engine feels smooth but not really powerful. I had an SR before this and it felt a whole lot better. Do you think i might have a bad cas or maf?
