TIMING PROBLEM NOW/CHAIN WAS BREAKN,BUT NOT BROKE YET
vacnsewmedic
Car: nissan
I NEED SOME HELP WITH THIS DO-IT MYSELF JOB,
I HAVE A 91 240SX, I NEED TO START FROM THE BEGINNING TO GET IT TIMED, CAN SOMEONE PLEASE HELP, IM GREAT WITH GETTING THINGS WORK'N AND I HAVE THE FSM SO I BOUGHT A NEW KIT AND INSTALLED EVERYTHING, JUST NEED TO LEARN ABOUT GETTING TIMING TOGETHER.
PLEASE, TYCOREY
s13sr20chris
valve timing? or ign timing?
vacnsewmedic
Car: nissan
WELL, ITS NOT IGNITING SO MUST BE IGNITION (RIGHT) I THINK
BUT, I BELIEVE I SLIGHTLY TURNED THE CRANK OFF A BIT,
WHAT ARE SOME BASICS TO GETTING THIS THING TIMED AGAIN...
s13sr20chris
ok, shes all back together and wont start right? turn crank to tdc and pull valve cover. both valves should be closed. that means your on the intake stroke. if not turn the crank 360 and see if that helps. now are the valves closed? where do the cam sprocket notches point? what about the little dots? some dont have the dots.
vacnsewmedic
Car: nissan
where would the notches be on the cam sprockets?
and when your on the intake stroke, does that mean that both valves are pushing the cylinders down?
tdc is when you take the first spark plug out and its at the highest point if u stick something down in the hole(feeling the stroke come up) is that a way?
DAEDALUS
Car: 1990 Infiniti Q45
The notches are little round dimples on the sprocket under one tooth. Some sprockets have 2 dimples, though, look for a dowel pin under one if that's the case.The valves don't push on the piston. On the intake stroke the intake valve is open and the exhaust valve is closed, but there might be a little overlap, so at top dead center both valves might be slightly open. The exhaust will close as the motor begins to turn.Find TDC with the marks on the crank pulley. Going with something in the spark plug hole will get you close, but the marks will get you exact.
vacnsewmedic
Car: nissan
DAEDALUS,
GOD, I think with this type of support I will be putting my Volvo up for sale...lol NOT...
But I do want to get this car together, its pretty sporty
I want to thank you for all your help, and Im sure Im not done irritating yall yet..lol
thanks again
Corey
