SMoKeM240 »
https://forums.nicoclub.com/smokem240-u21823.html
Sun Dec 05, 2004 9:15 pm
i rebuilt my motor, deck the block and shaved the head. Sohc by the way, when i was putting on my new timing kit, i put the cam notch straight up, and the marking was pointing 3oclock and if the put the crank notch straight up (tdc) the colored links dont line up. they only line up if the crank notch is like this ( \ ) so should i take it apart agin and put the cam and crank straight up and not line the links up?
