Timing Problem help!
cr0nict0k3
Okay so i just did a timing chain job on my ka24de, and i have all the cams and chain lined up exactly like the jim wolfs, and exactly how it was before i replaced the chain, timing reads that its 20deg before and everything is set right, but it runs a tad boggy and lacks power. Anyone know what this could possiblly be?
cr0nict0k3
its also advanced at the distributor to make it run decent when set at TDC its really boggy
Modified by cr0nict0k3 at 12:49 PM 6/28/2008
cr0nict0k3
it also sounds like my intake is sucking way more then my exhaust is pushing out
cr0nict0k3
my idle is stable and its just lacking powering uptop and i have to run it advanced at the distrubutor for it not to be boggy commmmon anyone?
