Timing on SR
clutch Kick drifter
Car: 1992 Nissan 240sx/ Blacktop SR20det
When you take the timing light and point it to the crank and your turning the Camshaft posotioning sensor which marking should it be on the crank? Ive heard 5th from right and 5th from left and diffrent things and wanna get it cleared up because im racing tommorow and need to know ASAP>
ILikeMy240sx
Car: SR Power
15 deg +- 2 according to the FSM which is the second mark from the right.
Each mark is 5 deg
clutch Kick drifter
aight thanks man.... thats where it is right now but it was bothering me
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
hehe mine has problems. mine runs fine other than idling at 2000rpm. no detonation even hot days with stock everything and 3" DP + exhaust. when i shoot my advance gun with the pickup around the #1 cyl's loop, all the dots appear on the bottom of the crank. i know the O2 and TPS sensors are bad. possibly others. when i tried to put the crank position sensor so that the dots appear at the top so i could time it, it wouldn't run. hrmmm . . .
luv2spedup
Car: 89 silvia
ILikeMy240sx wrote:15 deg +- 2 according to the FSM which is the second mark from the right.
Each mark is 5 deg
thats rite
95lstegman
hey guys, i learned a nice trick for getting the timing right. get a spark plug wire from an SE-R (or any plug wire with a long enough boot to get down to the SR20DET's plugs) and connect the boot to the #1 plug. then take the lead off the back (top end, when installed) off a spark plug and splice it onto the other end of the spark plug wire in place of the dizzy connector. then connect your SR's #1 coil pack to the end of the custom spark plug wire you just made. now your car will fun fine, and you can put the inductive pickup around the spark plug wire instead of the loop at the back of the valve cover. it's a lot more consistent. my car now runs fine, not like a half-@$$ed project car.
Hijacker
Car: '92 240sx Convertible
'94 F-150
zerothread?id=59684nobody has ever done anything like that before...
95lstegman
well i just figured i'd help some people out. i had never heard of it until recently, and i found it gave a much more consistent reading than the loop by the back of the valve cover. i thought that's what this forum was about, right?
Hijacker
'94 F-150
sorry, my humor can be quite sardonic at times. I didn't mean that as a personal attack. These boards are meant to be a help, and I'm happy that you're helping.
clutch Kick drifter
yeah thanks to everyone for helping. I ordered my coilpack a few days ago and it will be here Monday, but i think its my plugs.
95lstegman
clutch Kick drifter wrote:yeah thanks to everyone for helping. I ordered my coilpack a few days ago and it will be here Monday, but i think its my plugs.
copper plugs are like $10/set for SR20DET. why not try those before ordering a $75+ coil?
clutch Kick drifter
already did and didnt fix it... just got coilpack in.
Modified by clutch Kick drifter at 6:53 PM 11/15/2005
