boro drift »
https://forums.nicoclub.com/boro-drift-u103655.html
Sat Dec 20, 2008 7:40 pm
The reason you rev the engine before and after you unplug the tps is to keep the exhaust temp above 600 deg so the O2 sensor is doing it's job and the ecu is operating in closed loop. In my case, when I would unplug my tps, the idle would go up, so I would re-adjust the idle and reset timing, several times, before I got it dead on, all the while reving the engine to keep egt's up. Once egt's are up, the idle, with the tps disconnected, should drop. It's a couple of hours of screwing around, but you'll get it.
edit-The three revs above 3000rpm with the tps unpluged puts the ecu into timing mode and this is also the mode for adjusting the idle.
