What can cause the ignition timing to be off by 11 degrees without touching the distributor? A smog tech measured my timing to be 9 BTDC. Also another mechanic that I know confirmed that the timing was at 9.
3 days before, the smog tech measured it be 20 BTDC, but I never touched the distributor. I had the bolts on the distributor marked when I did a timing chain job years ago, so it never moved from that position.
SO this makes no sense to me. Need some input, because my car does not run right after I had the timing readjusted to 23 BTDC.
Here is how the distributor looks now for 23 BTDC. The black mark indicates where the middle of that bolt was originally for 20 BTDC.
Uploaded with ImageShack.us
