Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Tue Aug 09, 2005 4:34 pm
Your battery light should be on when the key is on but the car isn't. Did you have the engine at TDC when you put together the new timing assembly? If so, did you line up the silver links on the chain with the dots on the sprockets?
If not, you got a lot of work ahead of you.
