timing marks wont line up right when i put new belt on Help!
Zdriver
Car: 1990 Nissan 300zx Z32
hey guys i went and got a new timing belt and i got it put on but when i get got it TDC with the new belt on the cam gears wont line up perfectly. each cam gear mark isnt even a tooth off.(the marks on the backing plate are right in between each tooth) i can get 2 gears perfectly lined up but the other two are just off by a little bit. and the crank gear is a bit off its mark to. and i have the tensioner so its not tensioned at all and the belt is still tight when i put it on. and the tensioner wont actually put any tension on the belt. any suggestions?
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
The marks on the back plate are just guides assuming your right at tdc. Align the belt with the marks on the cams and sprocket they all have a little dot on them to indicate where the mark should line up.
RubyRed300ZX
Car: 1993 300zx Convertible
If the tension on the belt, without the tensioner touching it, is already tight, I'd be worried that somebody gave you the wrong belt. I'd remove it and start by first checking that is has the correct number of teeth. I believe it's suppose to have 228 teeth. Check the technical manual. It also lists the correct number of teeth between each pulley. Also verify that the belt has the correct pitch for that number of teeth (hence the overall length).
IonZ32
Car: 1990 300zx TT
1992 300zx
1964 Malibu
Like mentioned above, dont worry too much about the marks on the backside of the cover. As long as all the cam alignment marks line up with the marks on the timing belt and the crank mark you are fine. The 4 cam marks will be somewhat close together and then one mark spaced apart is the one for the crank.
Zdriver
thanks guys the lines on the belt lined up perfectly on the cam gears and the crank gear its set right now
