Timing marks on the CA20E Engine
YellowPreludeR
Car: Cars...women...cars with women in them....
Im having trouble setting the timing with the CA20E engine i have with the vacuum advance. There seems to be 6 timing marks that I highlighted with whiteout.
||____||_____||____||____||____||
thats the current timing position with the car idling at 750 rpm and the vacuum advance both plugged or unplugged either works.
As the car RPM goes higher and the bottom pulley spinning clockwise, the timing mark moves to the right.
The car says it should be at 4*BTDC but i dont know which one is correct. Lemme know where the mark should be so I can get this done correct. Thanks.
themadscientist
Well the CA18DE's marks starting from the left are; -5, 0, 5, 10, 15, 20. I would see no reason why the 20's pulley would be different.
YellowPreludeR
so according to my wonderful drawings...am i at the 4* BTDC that i need it to be at? cause if i am im not going to fool around with it.
YellowPreludeR
my car says that i should be a 4*BTDC.... someone please use my example from the previos post and show me where on the timing thing should my marker be when idling. WHere is 4* BTDC cause i cant tell just be looking at the marks. What direction is BTDC and ATDC? Thanks
themadscientist
according to the top diagram you are at 11 dgrees advanced
YellowPreludeR
so===||===\/
is that where i need to be?
DAEDALUS
Car: 1990 Infiniti Q45
Hold on, according to the top diagram he's 11 degrees before TDC, right? The more clockwise the point at which the spark fires, the more advanced the spark timing, right? I would think 4 degrees BTDC would look more like this:
5ATDC 0 ........5BTDC...........15.......20
YellowPreludeR
lets get another opinion !!!! :D comeon more ppl !!
themadscientist
YellowPreludeR wrote:so===||===\/
no that would be abou 2 degrees AFTER TDC, Daedalus' one is what it should look like.
YellowPreludeR
thanks
