Phram1 »
https://forums.nicoclub.com/phram1-u217282.html
Fri Mar 07, 2014 12:10 am
Thanks for the advice. SDS I have uses rpm and map sensor when programming timing and fuel. Though it is 2dimentional rather than 3, I can get very close to a good tune using this system. Other tuning tool include a PLX wide band and the sds data logger which is built into the sds CPU. However, In another post I mentioned heading for a Vipec i44. Now I just need to find a used one a good price. N That combined with a plx wide band.
Noted, your advice 18 degrees at idle and add a couple degrees ever 1000 rpm. That would be 30 degrees total timing. What would you pull out at 5-10-15 psi boost?
