Timing map for power fc and z32 maf....
al_v
Car: 1998 240sx
Please can someone share with me ,a timing map for the power Fc with z32 maf , I found a timing map in a australian forum , but not sure if is using z32 or q45 maf , and I need a map for 91-92 octane pump gas.
Thanks.
Carl H
just use the stock timing map...its conservative enough.
al_v
Car: 1998 240sx
Carl H wrote:just use the stock timing map...its conservative enough.
The stock timing map is made for stock rb25det maf , if you change to z32 maf , the load points are very very different , you will need a completely new timing and injector map....
240z4u
Car: '95 Nissan 240SX
Carl is right.
Apparently, you did not notice you can change your selection of MAF on the power FC to a z32 maf. It corrects the load points.
No, I don't remember exactly where it is but its in there for sure.
Evan
Can you put up a link to the Australian timing map?
al_v
Car: 1998 240sx
240z4u wrote:Carl is right.
I know that I can change the maf ,but didn´t know that the load points are corrected, I will check that tomorrow.
Evan
I don´t remember the link , just have an excel file saved in my computer , and this forum doesn´t have any option to attach files. If you give me your email I can send the file to you.
240z4u
Yeah it corrects points.
Ill send you my email.
Evan
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
240z4u wrote:Yeah it corrects points.
This is one of the nice plug and play features of the PFC versus having to input the load curve for your MAF. Not a big deal, but convenient nonetheless.
As far as your maps changing, I'm not sure.
s14_girl
Car: Nissan 240sx ('96 s14 w/ SR20DET RIP) '95 s14 w/ RB26 current
Sorry to semi-thread jack, but I have searched and not come up with anything satisfactory. Is anyone running something bigger than the z32 maf with the power fc? I need to know the capability of it to run a lightning/cobra maf. Thanks!
Darius
You can run any maf you want, but you have to know the volt-to-load curve for the one you choose so you can input the points into the PFC.
s14_girl
Thanks for the help!
240z4u
S14 girl, if you do have luck plotting a graph for a cobra maf please share.
I don't need anything that big but it would be a killer option!
Evan
s14_girl
My PFC comes in Tuesday, so I'll see what happens and let you know
