Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Tue Aug 19, 2003 6:30 pm
Try moving the induction clamp around - sometimes if it is too close to the plug end, or another source of interference, it won't work properly. I had the same problem until I shifted the induction around on the wire, then Pop! it appeared.
I'm not sure what kind of light you have, but it is really hard to see mine in daylight, I have to use it within a garage to see the strobe.
