RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Mon Dec 08, 2008 11:34 am
So I've had my ca for almost 2 years now. When I first installed it, I set the timing to 15 degrees (2nd tick mark from the right). Ran great no probs for several months....then one day it started missing under wot in upper gears. Checked the timing and it was between the 10 degree and 15 degree mark I re-set back to 15-17 degrees, and it was back to strong pulls with my wot miss gone. About 6 months later, same thing....started missing at wot in the upper gears. Checked the timing, and it was back down between the 10 and 15 degree marks. Re adjusted it back to 15-17 degrees, and back to running normal. About a week ago, I got the miss again at wot.....checked the timing today, and it was down closer to 10 degrees . I re-adjusted it back to 15-17 degrees...haven't test drove it yet, but if history repeats itself...the miss should be gone(I'll drive it here in a few hrs).This can't be normal....anyone else have this problem? Is there something that needs replacing or something?
