Not_a_sr »
https://forums.nicoclub.com/not-a-sr-u23501.html
Wed Jul 05, 2006 10:23 pm
check your mechanical timming by putting the crank on 0deg BTDC then make sure your cam marks align with the cover behind the cams, you will have to take off the top cover and CAS. when that checks out fine, check the little tooth on the exhaust cam that the CAS runs on , its possible its worn out. then check the CAS with a known good one. also when setting timming make sure the car is at full operating temp. i have had to chase this problem with every single CA ive worked on not just my own.
this year alone i think i have thrown out 5 CAS sensors and two or three exhaust camshafts. cant wait for my megasquirt to be finished so i will never have to deal with that crap again!!
PS any one have a TPS plug off a old KA or CA harness i could really use one!!
