chillmieste »
https://forums.nicoclub.com/chillmieste-u561.html
Mon Jul 25, 2011 11:57 am
s13 and s 14 slightly different when doing the pan. I like to jack up the trans on the bellhousing, unbolt motor mounts to get enough space then the pan should be a breeze to take out. Not sure what tune your using, but stock timing is 20 degrees, but if inserted correctly you should have more than enough space to bolt it up. I would use a scan tool if you dont have the timing marks or u should even hook back up the old crank pully and get a timing light. Ignition timing very important, if not done right ur car wont start or if not at the correct timing( depending on ur tune) could cause u detonation. be careful as ur long hours of work could go to waste.
