24_4life wrote:I used the dual exaust cams and when I put the cams in I didn't align the timming marks on the chains. As a result I cant use the timing marks on the pulley...
What, huh?
Yes you can.
The pulley shows when the motor is at TDC, and where the timing is in relation to that. Has NOTHING to do with cam timing.
IF you installed the cams and the timing is off...you need to fix that! Not try to determine ignition timing in some other manner.
The motor can run (barely) with the cams off a tooth or 2.
Fix that, then use the crank pulley to set timing.
- Brian
