If you have a KA24DE, your timing should be 20BDTC, not 16.petesleaf wrote:Check the vacuum hoses on the EGR valve at the back of the head. On the older ones the host to the valves melt from the heat. Make sure the EGR valve itself is popping up and down. They stick as they get carbon on them.
I set my timing at 16 degrees. It starts and runs fine. I believe the first mark on the pulley is 5 deg BTDC and the next mark is TDC. then 5 10 15 20 after top dead center. If anyone disagrees please post because this is how I read the diagram in my book.
