sleepsilvia »
https://forums.nicoclub.com/sleepsilvia-u37753.html
Wed Aug 13, 2008 12:08 pm
i'm in the process of putting my SR back together, and i'm currently setting the timing with the cam's. the problem is everything will be lined up, the bottom end is at TDC, the dark links match up with the markings on the cam gears, and the dowel pins on the cams are at 10 and 12 o'clock. but when i put in the tensioner, it moves the bottom end counterclockwise while the top end stays the same. how can i prevent this from happening?
