frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Fri Dec 17, 2004 6:47 pm
Alright, the story: 1990 Chassis, 95 ka24de. Runs great, idles fine, accelerates and operates soundly, good gas mileage, can race, etc... Went to check the timing to finish up a tune up, and had a solid 20 degrees; Like we should. Then I remembered we have to disconnect the TPS to get base timing and be sure its all in line. So, I disconnected it, and time it out, WHAM, I'm about 20 degrees advanced!!! Idle is about 1500 rpm now. I found this really odd. I then adjusted the Idle air contol and I'm not getting any results, so I rotate the distributor, still nothing desirable. I decided to leave it alone, and just reconnect it all and go on my way home. Ran fine, idled like usual, no pinging, knocking, leaning out, normal mechanical shape. Any ideas on what is wrong? I also have a leaky brake booster, but I don't think it would contribute to what I am observing. All marks and links are lined up perfect... HELP!
