rudee023 »
https://forums.nicoclub.com/rudee023-u4970.html
Wed Dec 22, 2004 2:42 pm
Firt off I have searched through every timing thread on this and other forums and I seem to be back to square one. Originally the CAS was set at 15BTDC (according to timing light on loop or (-) wire on coiplpack, both read the same. However, the CAS was at the end of it's adjustment range clockwise (wrong according to many), not to mention the motor felt as if it were holding back.
I removed the valve cover to restab the CAS, set the crank to TDC lined up the marks and inserted it with the adjustment holes in the middle. Started the car and it idled like crap but ran o.k. WTF? I thought once you set it the valve cover way that was it, no more adjustment needed.
Checked the timing again the same way as before and it read 0 degrees TDC. After adjusting it to 15, the idle is perfect and the car pulls like a mo'fo but guess where the CAS is at again. Yep, near the end of it's adjustment. BTW my friend's clip with only 50,000km(that's right, km) still had the Nissan OEM tape unbroken holdling the CAS and his is the same as mine. My last attempt will be to use the spark plug wire method to see if I get a different reading. It would be nice to get the final word on what is going on.
