Figured I'd jumped a tooth on install somehow, so bit the bullet and pulled everything apart and re-did the timing belt. Double, triple, quadruple checked all the marks on the belt with the marks on the gears and the backplates. Followed the procedure in the FSM, turned the engine to take the slack out. Waited a few hours, and tensioner was still right at 4mm. Buttoned it back up, exact same issue. Down to the chugging and feathering the throttle. Timing still exactly the same at 35-40 BTDC. Starts chugging when CAS is retarded past where it currently is. CAS was indexed and reinstalled in same orientation when I reassembled everything.
Click for video:
video-1529807062 by theaaronparris, on FlickrDeleted everything there is to delete except PRVR. 740cc injectors and dual MAF, with a proper chip from Z1. As mentioned, brand new harness. Upgraded piping and exhaust. Auto to manual conversion with the conversion harness from Z1.
I'm out of ideas. Is it possible the new ECU chip has a bad timing map in it? How can I verify that? Is it possible my pickup isn't working correctly and is showing far before the actual plug is firing and I've actually got a different problem? Could it be a CAS issue, even though the CAS seems to be adjusting correctly? Help me out guys.
